There are two (or three, can't remember) screws (torx head) holding the headlight assembly in. One is on the inside edge of the light, accessible by opening the hood and moving a rubber flap out of the way. The other one (or two) are on the bottom edge. If you look straight on under the bottom edge of the light housing, you will see a small indent in the bumper cover that will allow you to get at that one. Then the housing pops out.
