Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
ODB II Tools
Old 10-19-2017, 03:46 AM
JourneyManZA's Avatar
JourneyManZA
JourneyManZA is offline
Default ODB II Tools
Hi there. I did a search for ODB II diagnostic tools and didn't find any. Would it be possible perhaps to create a sticky with the best ODB II scanners and tools? I'm looking to get the bluetooth adapter and I'm not sure if this will be worth it or not. Any advice would be greatly appreciated.
I have a Dodge Journey 2009 RT 2.7 V6
Old 10-19-2017, 08:02 AM
jkeaton is offline
It depends on what you want to do. You can buy a scanner ffor under $20 these days if you just want to read and erase codes. Or you could spend several hundred on one to do more things like data logging, real time data, etc.
Old 10-19-2017, 08:17 AM
JourneyManZA
Well right now I just need to see what's causing this intermittent engine check light I'm getting. I have purchased a OBD 2 bluetooth reader and I'll use my android phone to check the error codes.
Can anyone recommend and app of choice for this?
Old 10-19-2017, 08:19 AM
jkeaton is offline
Have you read the code yet? That's a good starting point....
Old 10-19-2017, 09:35 AM
JourneyManZA
Nope. Soon as I get my OBD reader it's the first thing I'm going to do. Which is why I asked about reliable android apps for the task at hand. I see that the Torque app is a preferred way of doing quite a few things with the bluetooth adapter.
I'll let you know what codes I get.
Old 10-19-2017, 09:43 AM
primem's Avatar
primem
primem is offline
have not found a phone linked scanner that is any good
for under $100 you could get a launch c-readervi. i have one. Its fast, operates all 10 modes of obd2, free for life updates
-reads clears codes- powertrain only
-live data stream
-graphs data
-clears dtc
-freeze frame data
-i/m monitor status
Old 10-19-2017, 09:48 AM
JourneyManZA
$100 dollars in my country isn't cheap. Besides. Scanners are hard to come by here. So I hope I can make some headway. Dealers will charge ridiculous amounts to read the codes. Then supply you with reasons why they need to replace half your car.
I've just had the ignition module factory recall done. At least that was free.
Old 10-23-2017, 03:35 AM
JourneyManZA
So I managed to get everything working. The only code I was getting was the throttle position sensor error code.
P0122-THROTTLE POSITION SENSOR 1 CIRCUIT LOW
P0123-THROTTLE POSITION SENSOR 1 CIRCUIT HIGH
So my next question would be. Do I replace it? Or is it a serviceable part?
Old 10-23-2017, 10:13 PM
primem's Avatar
primem
primem is offline
history or current codes? if you unplugged the tps connector with the key in run the p0123 dtc with set. if they are not active dtc, clear them and set what resets. its not logical to have both codes at the same time as one is for an open circuit and one is for a shorted circuit. the fault could be a wiring, pcm or tps fault so test the wiring first, if its ok, replace the tps, if the fault is still present, replace the pcm.
Old 10-24-2017, 12:30 AM
JourneyManZA
Thanks @primem I will do that and post my findings.
The weirdest part of this is that the car is running just fine. Good throttle response etc. I had the throttle control light on the dash a few nights ago but it never happened again. And then the ecm light seems to switch off after every 3rd or 4th start and then comes back on while I'm driving with no effect on the vehicle. Possible signs of a failing tps?
