No key. How do I remove the cylinder or options around it?
Old 10-19-2017, 06:59 AM
dhmnuts's Avatar
dhmnuts
dhmnuts is offline
Default No key. How do I remove the cylinder or options around it?
Hey, we lost a key for a 2002 Dodge Dakota RT and we're trying to replace the ignition cylinder. Any way to get it out without the key or maybe any other ideas on how we can get the original key. Anything.
Old 10-19-2017, 07:08 AM
dhmnuts's Avatar
dhmnuts
dhmnuts is offline
Also, I believe it's a non-transponder key.
Old 10-19-2017, 10:20 AM
Received 3,166 Likes on 2,920 Posts
Need to disassemble the steering column...... Once you get down to it, shouldn't need the key to pull the cylinder.
Old 10-22-2017, 08:29 AM
Dodgevity's Avatar
Dodgevity
Dodgevity is offline
Try the dealer. See if they can cut you another key if you bring in the title.
Old 10-22-2017, 07:15 PM
magnethead's Avatar
magnethead
magnethead is offline
I've been told that the key files for our trucks may no longer exist due to age...mixed answers depending on who I ask.
Old 10-22-2017, 07:35 PM
Call the dealer with your vin, and ask them if they can cut you a key.
Old 10-22-2017, 08:54 PM
magnethead's Avatar
magnethead
I have 2 SKIM keys and a black key, i'm good. OP might ask tho.
Old 10-23-2017, 10:23 AM
TNtech's Avatar
TNtech
TNtech is offline
Site Moderator-Dodge Tech
I can still get my old 97 key code. An old dealer will still have a book with codes.
One of those fancy new FCA facilities that they'll never make their construction money back on won't have one.
If all fails, the lock pin on the cylinder is softer than the metal around it. If you hit it enough with a punch chisel, it will flatten enough to get the cylinder out. I do it quite frequently here.
