Hello! new to the forum... with some truck issues.
Old 10-21-2017, 04:02 PM
TehMater's Avatar
TehMater
TehMater is offline
Default Hello! new to the forum... with some truck issues.
Hi guys! bought a dakota about two weeks ago in non-running condition. It's a 1995, 3.9 v6. it will crank but not start. wasn't getting fuel pressure so i put a new fuel pump in, along with an ignition coil. sometimes it will start and run for a minute or two, and then just cut off and won't start back up. anyone got any ideas on what could be wrong?
Old 10-21-2017, 09:08 PM
robertmee's Avatar
robertmee
robertmee is offline
When it shuts off and won't restart are you missing fuel or spark? Really zero information to go on.
Old 10-22-2017, 01:13 AM
TehMater's Avatar
TehMater
TehMater is offline
I'm getting fuel. Thinking it's a spark issue but I'll have to pick up a tester next payday to be sure. Splice under the fuse box has been repaired just to rule it out, as well as switching relays around
Old 10-23-2017, 07:22 AM
smokin1994's Avatar
smokin1994
smokin1994 is offline
I know I had an issue with my ignition switch. Mine would die, but the dash lights would be on,
