eBay Shorty Headers
eBay Shorty Headers
Ok, so what's the deal with these? How many of you are running them, for how long, and how have they held up? In my search I have only found 1 long term review and they had nothing but good things to say. At just over $100 delivered how can you say no? I currently have a set of Edelbrock shorties that I got barely used about 4 years ago and they are absolute garbage. The driver's side had recently cracked on one of the downtubes where it is welded into the collector and leaked / sounded terrible. I hauled it off, cut the collector in half, welded the tubes inside as best I could and welded the collector back together, but it still ticks a little bit (I assume I didn't weld it 100% - very awkward spot - header leaks drive me absolutely nuts). They also use graphite donut seals at the Y-pipe connection which are just awful and have rusted a fair amount as well.
The eBay ones seem to be made of T-201 SS which...I guess is not the greatest...but IDK.
Comments?
https://www.ebay.com/itm/Dodge-Ram-1...laAq3a&vxp=mtr
Comments?
We got a set for my daughter's chevy 2 years ago. I think they are Manzo. They fit well, have a thick flange and are 14 gauge. I really like them. I will try to find the Manzo shorties on Ebay when I get around to putting a set on our dodge. https://www.ebay.com/itm/Manzo-Stainless-Steel-Exhaust-Headers-Dodge-Ram-Durango-Dakota-94-03-5-9L-TP-210/380821454331?epid=1737472376&hash=item58aaba3dfb:g UkAAOSwrklU3jRG&vxp=mtr
I don't think that's the company we bought her's from but that's the brand.
https://www.ebay.com/itm/Manzo-Perfo....c100033.m2042
These have a better description, says 304 stainless.
I would go back to stock my friend. I installed pacesetters on mine and they rusted after a pismo beach trip so i replaced with JBA shorties. No leaks but they magnify the injector tick noise making it sound like a leak. If i could go back i would put the stock manifolds back on. never worry about leaks (no gaskets) and for my truck at least, the headers didn't do a damn thing for performance fuel economy or even sound (already had magnaflow muffler on).
The Manzo ones just look like a branded version of the no-name china ones (might even be the same grade of stainless....who knows). Good to know they are working well.
And yes, I have already considered going back to the stock manifolds, which is not out of the question. I did notice a big sound difference switching to headers however, which is part of the reason I wanted another set of shorties. The thinner wall of the tubes and ticking of just exhaust flow might drive me up the wall thinking it is a leak as well. Hmm...
I've got JBA shorties. They started to rust after 1 year, removed em and got em powder coated for way more than they're worth. the heat from headers will toast your sparkplug wires and you'll need heat protective sleaves over the wires as well as a new wire support guides to keep them off the headers. Might want to stick with the manifolds unless you want to deal with all that.
I'm using the Pacesetter shorties. They're not even stainless, just mild steel and very thin. I coated the inside with Eastwood Internal Header and Exhaust coating (ceramic) and it's actually amazing. It keeps the headers from putting off much heat at all. They actually seem cooler after a long drive than the manifolds were! For something that comes in a can and cost $30, I still can't believe how well it works.
Also from all the complaints I've read, it seems that most of the aftermarket headers have trouble getting a leak free seal to the heads with normal gaskets. Mine were no exception. As 2bit suggested, a set of Remflex gaskets will cure that problem.
