tie rod end (and drag link) taper dimensions...
I feel like I should be able to find this on the web or here using search functions, but have been at it a while and just can't seem to... ;-/ Anyone know off the top what the dimensions of the tie rod end taper for 2nd gen trucks are? (ie max, min and length) I know the taper / angle, just not the specific dimensions. Thanks!
I'm modifying a dropped pitman arm for a project and need to flip the drag link to the other side. Going to bore the hole out oversized and turn a sleeve with the right taper to slide / weld in from the other side. I can get close by measuring the drag link, but was hoping to cut the taper to spec to be sure to get the best depth... I'm almost certain I've seen it somewhere, but can't for the life of me figure out where... grrr... oh well, Thanks!
Perhaps if you read the question next time you could provide some useful insight?
your linked search yielded even less information than all the ones I did... knowing the taper angle (it's 7 degrees or 1.5 inches per foot just like GM 1 ton tie rod ends), doesn't provide the dimensions to cut the taper such that the tie rod end seats to the depth intended by the designer... The 2nd gen dodge taper angle is the same as GM 1 ton, BUT the diameters are smaller... I was interested in the engineering specifications for the taper to ensure it would seat to the intended depth......
better?
maybe something here would help?
http://www.rockauto.com/en/moreinfo....366590&jsn=494
http://www.rockauto.com/en/moreinfo....366590&jsn=495
http://www.rockauto.com/en/moreinfo....366590&jsn=496
there are a few tech specs on each of those.
Thanks! ...and sorry for being a butt last night! I forget sometimes how lazy some folks are - I guess I've just gotten to the point where I ignore it and forget that just because I know I dig for things and think through them carefully before just randomly posting for help on message boards, doesn't mean that others will know / assume that I do...
What's funny is that we apparently think alike ... Before posting on here, Rock Auto was one of the first places I looked when google, pirate4x4, here, a couple others didn't yield results, then from rock auto to moog problem solvers / tie rod end specs on their web page armed with part numbers... I included both the standard y-type steering and the 98-99 HD T-type steering setups (I have the second fitted on the dana 60 on my van, soon on my truck - highly recommended change from the Y-style..). Moog generally shows the max and min taper diameter on their site for their products and I've found it very helpful when trying to fit oddball things together like this in the past. ...but those columns are blank for the ones that cross-referenced to dodge tie rod ends fitting the gen 2 trucks with 1.00 x 16 threaded ends. I emailed moog customer service but haven't gotten a reply yet and didn't have the patience to wait until tomorrow to call and try to get through the layers of people. SOOOO being the smart guy that I am (I'm kidding...), I finally just did what I should probably have in the first place - I grabbed a mic and d measured I have a half a dozen used new tie rod and drag link ends, three pittman arms and the knuckles on a dana 60 and dana 44.
for future reference I wound up with 0.95 in long taper that would be 0.60 min diameter and 0.70 max diameter (the average I wound up with from the measurements...) and the pitman arm I'm using is 1.1 in thick the knuckles a bit thicker... both having the same taper...
first: you would be amazed how many people don't know how to use google. second: refer to HeyYou's post. Third: a suspension manufacturer like moog might be able to provide what you are looking for, but you will likely have to contact them directly. it will probably take some time before you get past the morons and get hold of someone that cares or has the authority to care. Dodge may even be of help, but again you have to get past the initial morons that tell you they don't have that info. the parts are still made, so the spec sheet still exists.
better?
better?
