no voltage to fuel pump
Old 12-05-2017, 08:46 AM
Tommy714's Avatar
Tommy714
Tommy714 is offline
Default no voltage to fuel pump
2004 dodge stratus r/t.got such great help with this car last time here,i am hoping for a REPEAT! customer started car it died ,and then wont restart.no fuel,pulled pump had it tested(had been loud for a while).pressure fluctuated.replaced pump,now no voltage at pump,relay has voltage and clicks.pump runs when tested with leads.about to try to trace wire,any help on where or what to look for please.(electrical not my best subject)thanks.Retired tech ,left over customer wont let anyone else touch his ride.HELP!
Old 01-17-2018, 06:38 AM
jfprida's Avatar
jfprida
jfprida is offline
The same happened to my 1999 Stratus, apparently if used in extreme conditions the pump overheats, and the physical tin solder electrical connection to the pump melts and makes a bad contact, check the pump and it´s connections, doubt is a wire issue, check the tin solder to the connector in the pump
