2000 4.7 4x4 p0208
Old 12-11-2017, 03:22 PM
zach_smith's Avatar
zach_smith
zach_smith is offline
Default 2000 4.7 4x4 p0208
i have a 2000 durango 4.7 4x4 skipping and running rough. code p0208 is the only code i get. i have changed the injector #8, spark plug #8, iac valve, and the pcm. it still does the same thing wires seem to be good im just at a loss i need help anything is greatly appreciated
Old 12-11-2017, 03:58 PM
zach_smith's Avatar
zach_smith
i need advice really bad this is my daily driver
Old 12-11-2017, 04:19 PM
You have already changed the injector, and the PCM.... The code indicates a problem in the circuit for that injector. The only thing that is left is the wiring.........
Go to the parts store, beg/borrow/rent/buy a noid light. Plug it into the injector plug in question, see if you get a steady flash from the noid light.
Old 12-11-2017, 06:11 PM
zach_smith's Avatar
zach_smith
i have a test light that i checked it with. it flashes while its running, is that the same thing?
Old 12-11-2017, 06:39 PM
Pretty much.
does it flash steady? Not missing any beats?
Quick Reply: 2000 4.7 4x4 p0208
