99 Dodge Ram 1500 driver side lean
Old 12-22-2017, 05:52 AM
Kupisch98's Avatar
Kupisch98
Kupisch98 is offline
Default 99 Dodge Ram 1500 driver side lean
Hello I have noticed I have a driver side lean on my truck and I was wondering what it is, I have read on a couple forms and they all say it’s a spring problem but I just put a 5 inch BDS lift on it. Another problem I hear is the fuel tank which I do have the bigger one but I even have the lean with it being empty. Maybe it’s a bushing problem? It is about an inch difference.
Any info would be helpful thank you!
Old 12-22-2017, 10:09 AM
Interesting bumper, where did you get that from?
Generally, the lean is due to the rear leaf springs settling more than the passenger side.
Old 12-22-2017, 10:49 AM
Ramman18's Avatar
Ramman18
Ramman18 is offline
Well, Skyjacker makes two different springs for their kits that I had to make sure were correctly installed. Did BDS? There should be different spring rates for both coils and packs.
Did you know someone put the wrong bumper on your truck? Dodge would never have those lines mismatched like that. Seriously, looks like a nice rig. How about some more pics?
Old 12-23-2017, 12:33 PM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
He did what I did 4th gen bumper swap got mine for $100
Old 12-23-2017, 12:35 PM
MoparFanatic21
What size tires are you running. Which BDS lift did you get, do you like it?
Old 05-26-2018, 04:28 PM
Kupisch98's Avatar
Kupisch98
I’m running 35x12.5r22 I got the 5 inch with new leaf springs and the BDS shocks. It’s a great kit I would definitely recommend it!
Old 05-26-2018, 04:31 PM
Kupisch98's Avatar
Kupisch98
I put the bumper on myself I like the look of it better then my old faded stock bumper. Thank you I appreciate that. Here’s some more pictures.
Old 05-26-2018, 04:33 PM
Kupisch98's Avatar
Kupisch98
you can follow my Instagram page too for more pictures as well @kupisch_98 thank you for the info on the springs as well!
Old 05-26-2018, 04:36 PM
Kupisch98's Avatar
Kupisch98
it’s a 4th gen 2500 bumper, they make conversion brackets for 2nd gen dodges. I see thank you for the info! I guess I won’t really worry about it, it’s just one of those things where you notice it but can’t do anything about.
Old 05-26-2018, 05:50 PM
2bit's Avatar
2bit
2bit is offline
You could swap the springs from side to side or add a block on the drivers side.
Quick Reply: 99 Dodge Ram 1500 driver side lean
