Dtc P1391. 2002 ram 1500
Old 01-04-2018, 10:12 PM
shanes76's Avatar
shanes76
shanes76 is offline
Default Dtc P1391. 2002 ram 1500
2002 ram 1500 4x4 with the 4.7 and 179,000 miles cel came on truck was running like hell, felt like rear ended coming out from under it, pulled the codes and only code was 1391, replaced cam position sensor, drove a total of 35-40 miles light comes on, same code, crank sensor was replaced last year. Truck runs great. Light was on a few weeks before it acted up. Should I have put the electrical grease on the plug? It did look damp/ wet when I unplugged it. Bought the sensor at orileys and crank sensor I believe from autozone. Any ideas?
Old 01-05-2018, 08:58 AM
shanes76's Avatar
shanes76
shanes76 is offline
Can I spray a degreaser in the plug or brake parts cleaner then use dielectric grease? Would the inside of the plug being damp cause intermittent loss?
Old 01-05-2018, 09:06 AM
Received 3,164 Likes on 2,918 Posts
Not sure on the newer trucks.... but.... the older fellers REALLY don't like aftermarket sensors in critical locations. They just don't seem to give the proper signals. I would be tempted to pick up genuine mopar sensors, see if that didn't improve its attitude.
Old 01-05-2018, 11:44 AM
shanes76's Avatar
shanes76
shanes76 is offline
Could dampness in harness cause it
Old 01-05-2018, 12:51 PM
Possibly.
Old 01-05-2018, 03:59 PM
shanes76's Avatar
shanes76
shanes76 is offline
I just picked up some dielectric grease, also I didn’t unhook battery before installing, was in a hurry since it was -12 but it’s unhooked now just waiting to hook back up
Old 01-06-2018, 08:21 PM
shanes76's Avatar
shanes76
shanes76 is offline
Light came back on just by letting it warm up
Old 01-06-2018, 09:03 PM
You can try resetting again, and see what happens, but, if it comes back, I would be real tempted to replace both the cam and crank sensors with genuine mopar pieces.
Old 01-07-2018, 07:26 AM
shanes76's Avatar
shanes76
shanes76 is offline
The cam sensor fixed the issue I was having, but I will be replacing crank sensor today and getting the grease in the pigtails, supposed to warm up here today instead of this - temps
Old 01-18-2018, 05:48 AM
shanes76's Avatar
shanes76
shanes76 is offline
Light back on, I’ve replaced both sensors, was out for about a week then back on, same p1391 code
Quick Reply: Dtc P1391. 2002 ram 1500
