Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
passenger side no heat
Old 01-07-2018, 04:06 PM
czakoor@rogers.com's Avatar
czakoor@rogers.com
czakoor@rogers.com is offline
Default passenger side no heat
2012 Dodge Journey RT
Old 01-08-2018, 09:00 AM
jkeaton is offline
Nice detailed description. Good luck.
Old 09-22-2018, 05:03 PM
Al Mcgowan's Avatar
Al Mcgowan
Al Mcgowan is offline
mine was the same great heat on driver side nothing on passangers, from looking seems the heatercore needs flushed i live in a apt had no meen's to a garden hose so i changed the lines going into the heater core with each other put in a can of rad flush so it back flushed it's self.
mind you all that junk is still in the cooling system so drive for a few day's that way then drain the coolant to get the junk out and hook up the hoses the way should be you are good to go.
worked great for me had heat on passenger side in 5 mins.
hope it works for you as did for me
Quick Reply: passenger side no heat
