Lift kit
Old 01-14-2018, 09:29 PM
Chevierd's Avatar
Chevierd
Chevierd is offline
Default Lift kit
Does any one know if the suspension lift kits for the 99 down will fit a 2000 Durango or know what kind of modification I would have to make to make it work.
Old 01-14-2018, 09:40 PM
I am going to say probably not. You don't want to modify a kit to fit for a couple reasons..... First being, the kit is engineered for the year range specified. I don't know what changes they made from 99-00.... but, apparently they are significant enough that the kit won't be a direct bolt on......
Also, modifying the kit, and installing it on a vehicle it wasn't intended for will void any warranty that comes with it.....
It is really strange that I simply cannot find a lift kit for the 00 to 04 durango....... I wonder why that is.
Old 01-14-2018, 09:57 PM
jkeaton is offline
Is it torsion bars?
I see some torsion key kits on eBay. Or just crank your existing bars and add rear blocks or helper springs.
Old 01-16-2018, 03:54 PM
Pspklutch's Avatar
Pspklutch
Pspklutch is offline
It may be the swap to rack & pinion? I don't know why that would matter though. I didn't think they changed that much.
Old 01-20-2018, 08:24 AM
NCDurango's Avatar
NCDurango
NCDurango is offline
It won't work due to the rack and pinion steering
Quick Reply: Lift kit
