Steering wheel tilt lever broke off........
Old 01-18-2018, 11:32 PM
FLAMEROCKS's Avatar
FLAMEROCKS
FLAMEROCKS is offline
Cool Steering wheel tilt lever broke off........
As I was adjusting the position of my steering wheel, the TILT LEVER broke off. How do I go about replacing the TILT LEVER, & is this an easy job or are there springs involved complicating THINGS????
Old 01-19-2018, 12:04 PM
jkeaton is offline
Depends on what exactly broke....
Old 01-19-2018, 02:52 PM
Johnboy52's Avatar
Johnboy52
Johnboy52 is offline
Have you tried removing the covers around the steering column and looking at the lever? Most generally they will have a screw holding the lever onto the column. I had to remove those on many cars that I installed remote car starters in to access some of the wiring.
Old 01-19-2018, 02:54 PM
Johnboy52's Avatar
Johnboy52
If you are doing this under cold conditions be very careful not to break the covers. I would usually warm the inside of the car up by using the heater to make the plastic parts more pliable.
Quick Reply: Steering wheel tilt lever broke off........
