Vibrations...88 Dakota 2WD V6
Old 01-19-2018, 12:27 PM
Josh89Griffin's Avatar
Josh89Griffin
Josh89Griffin is offline
Default Vibrations...88 Dakota 2WD V6
Sometimes while at idle, there will be a vibration felt in the seat & floorboards & also a vibration felt in the seat, floorboards, & the rear view mirror glass will be vibrant from 55MPH & up.
I have all 4 new tires(same size & brand) installed, rotated & balanced, front end alignment done after the new tires were put on. I have installed new shocks on front & rear. New front wheel bearings & seals installed, along with new pads & rotors.
New ujoints, new transmission mount installed.
What am I missing?
Old 01-19-2018, 12:40 PM
robertmee's Avatar
robertmee
robertmee is offline
What am I missing?
If vibration at idle I'd check for worn engine mounts.
Old 01-19-2018, 03:58 PM
Josh89Griffin
It's hit or miss on vibration at idle.
You reckon a vacuum leak would cause this?
Old 01-19-2018, 07:43 PM
robertmee's Avatar
robertmee
Anything that can cause a misfire can certainly contribute to a vibrating motor.
Quick Reply: Vibrations...88 Dakota 2WD V6
