2010 Dodge Journey loses rpm's while driving
Old 01-22-2018, 04:29 PM
2010dodgejourney's Avatar
2010dodgejourney
2010dodgejourney is offline
Default 2010 Dodge Journey loses rpm's while driving
2010 Dodge Journey. Check engine light came on. Codes came up as Crankshaft and camshaft sensors replaced them all and replaced the coils and spark plugs car is still losing rpm's around 30 mph and wants to slow down and die out. Not sure what to do as the next step to try and figure out the issue. The codes were P0008 and P0009 and I replaced those sensors. The check engine light went out and then started back up again about 5 miles of driving the car. the check engine lights comes on and is blinking. Each time i have checked and the codes are different so i am replacing the items per the codes but doesn't seem to be fixing the problem. any insight would be greatly appreciated.
Old 01-22-2018, 07:48 PM
jkeaton is offline
This is the 2nd gen Ram section. Please read the section descriptions. You need to post in the Journey section.
Quick Reply: 2010 Dodge Journey loses rpm's while driving
