My durango started then stalled. I pushed button to start again just a click. It was below zero so I tried to jump and nothing. Change starter battery and relay. It just wont crank
Have you had the TIPM recall performed? If not, there's a temporary work around that's been posted/linked to on here multiple times. If so, it will be pretty easy to use a test light to confirm if the added fuel pump relay is getting trigger and if power is getting to the relay and out toward the pump.
You changed the starter, battery and "relay"? Which "relay"? Are you getting any error messages on the EVIC? Like maybe it's not detecting the FOBIK (key fob)?
The fuel pump relay/TIPM issue is a good guess, but if it's not even turning over I have to suspect something else. Do you have a spare key fob you can try? Take a look at this and give it a try...
