2002 Dodge Ram 1500 Quad Cab 5.9L won't start
Hello everyone new member to the DF and really appreciate all the information you members give out. Here's my problem I have a 2002 Dodge Ram 1500 Quad Cab 5.9L a/t 4x2 that will not start. No spark and fuel pump doesn't turn on when I cycle the key. All this happened after I replaced the transmission. The truck started up but was running rough so I left it running and went to get some gas for it when I returned 5 minutes later it was not running and hasn't been since. I have replaced the plugs,wires, rotor and cap, battery and TPS. I have read some things online about the wiring being a issue but I don't want to tear into that unless I have to and have a wiring diagram. Any help would be greatly appreciated. Thanks
I love my truck and don't want to have to get rid of it
365000 miles on original motor and when running is strong.
So here is a update on my problem. I checked the crankshaft position sensor and the wiring was pinched between engine and transmission was worn down to the wire so I replaced it. Still have the same problem no spark, no start. I really appreciate any advice/ information anyone is willing to provide. Thank you.
