1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Hey guys I'm new to the forum. I'm trying to figure out why my 4wd will not engage. I have manual hubs and neither 4 hi or 4 low will work. Transfer case feels as though its working, 4 low is as it should feel but front wheels will not pull. Please help!!!
best place to start is jacking the front axle up so both tires are off the ground and locking the hubs, should be able to spin the 1 tire and have the other tire spin too. it is possible that the hubs are not locking.
The Hubs are locked and wheels still spin free. Drive shaft will not spin. Any thoughts?
does it have a cad unit on the axle? if 1 wheel spins while the other doesn't the cad could be causing issues or there is a possible issue with the hubs if everything else it working but the hubs are clicking like you have said
