ready to swap in the monster 5.9
Old 02-15-2018, 06:51 PM
TheMadCanadian's Avatar
TheMadCanadian
TheMadCanadian is offline
Default ready to swap in the monster 5.9
iight guys so iv'e got everything to remove this little pony 3.9 magnum and put in a monster 5.9.
the engine is commnig in 2 weeks , come complete with flex plate , pcm , and harness. already paid and everything.
my truck is : 99 dakota sport v6 3.9L magnum auto 2wd.
engine from : 01 dakota r/t v8 5.9L magnum auto 2wd.
i'm using my 42RE... for now.............
what am i better with ? my v6 ecu or the v8 one ? ( 1999 v6 and 2001 v8 PCM )
also will my cluster work or i'm better buy a 01 one ?
for sure i'm not gonna play with wires under the dash... it's pita in case i have electrical problem and i fixed it for good because of that ( removed connector and soldered wire by wire ). so ill do it next to the pcm with loom and heatshrink.
i did read the amazing red9535 thread for the swap but i'm not sure... the seller said i'm way better with the pcm that come with , but some other says keep v6 ecu...
TIME is not a factor. i can take a month or two to wire it.
Old 02-15-2018, 07:14 PM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
You'll need a new PCM, for a 1999 5.9l or you could try the 3.9.
The '01 PCM won't work. Dodge changed from the CCD bus (2 wire) to a PCI bus (1 wire) in '01. It's not just the cluster but EVERY module, ABS, airbags, PCM, CTM, and cluster won't work.
Old 02-15-2018, 07:23 PM
TheMadCanadian
alright thanks. ill wire my v6 pcm for now and later get a 99 v8 pcm.
can you tell me why they say i NEED a pcm the same year as my truck even on a newer v8 engine ?
i guess its for the ccd - pci bus thing but maybe there another reason... like maybe just way faster and easier..
when the engine arrive ill remove snow and ice to get the truck out ( stored for winter , the good old way )
Old 02-15-2018, 09:23 PM
Dodge made subtle changes thru the years, and even sometimes, mid-year........ so the interchangeability is rather limited. You will need to have the 6 PCM flashed for the 5.9.... otherwise, it won't be aware of the other two cylinders.
Old 02-15-2018, 10:24 PM
TheMadCanadian
thats not what everyone else say. not saying you are wrong.
even a friend with a swapped 318 told me all he did was add 4 wires for 2 injectors and extend a sensor wire.
Old 02-15-2018, 11:59 PM
magnethead's Avatar
magnethead
magnethead is offline
No, you'll have to have it reflashed. Even at that, not all V6 PCM's came with the pins for injector 7 & 8 populated/connected internally.
Old 02-16-2018, 12:38 AM
TheMadCanadian
ok. because FSM have injector driver pins and wiring pinout for all engine , for 98 durango and 2000 dak and ive read another thread somewhere the dude says it can be done it just dont run perfect ( without reflash ) as a temp solution waiting to find a PCM.
if i can find the thread ill post it
2000 dak
98 durango
Old 03-03-2018, 02:52 AM
TheMadCanadian
NEWS !
i got the engine yesterday. very clean.
it came with the 01 ram ecu but i knew this wouldnt work so i told him to keep it and saved 50$.
i tried my v6 pcm , nothing
i looked everywhere for a 99 5.9 pcm with no luck. i found one at "car-part" but the seller wont ship.
all i can get is 98 and 2000 5.9 pcm or 99 5.2 pcm.
i know 5.2 will work " fine " but not at 100% of its power. but how much ? wount it run WAY too lean ?
i know a lean condition of say 15.7:1 isnt that bad unless you are forced induction but stock is ok. not the best but still fine.
in just 3 calls i could buy about 20 used 99 5.2 PCM. they are everywhere. and near me.
those options are out of questions because canada = scammer. even shipping outside canada is a scam. ( quoted 940$ CAD at 4 dealers for a reflash and take a month + 200$ for shipping both way )
- reflash.
- buy used online.
- shipping outside canada.
so why a 98 PCM wouldnt work if the FSM are the same 100% ? i had a 98 durango cluster in my dak so this isnt the problem as it was working.
Old 03-04-2018, 12:40 AM
magnethead's Avatar
magnethead
Get a 99 5.2 PCM. The O2 sensors will even out the fuel trims into decent approximation. Or you can get with somebody [Cough]Flyin Ryan Tuning[/cough] for a 5.9 reflash tune.
Old 03-04-2018, 12:53 AM
TheMadCanadian
like i said , reflash , tune, or whatever related to programming or two-way shipping is a NO GO here.
so if the 5.2 PCM will work fine for the 5.9 , i'm in business. i can get alot of them for 99.
Quick Reply: ready to swap in the monster 5.9
