5.7 Hemi Oil Pump
It should be possible to remove the oil pump without pulling the oil pan. Only problem i see is the oil sump needs undolted and moved down. I would recomment pulling the oil pan off tho. Not that much more work to do and if your oil pump failed then it wouldnt hurt to inspect the sump screen and check your rods for play. Would also replace the timing chain since you will be removing it. Just be happy its not a 4.7. Easy job on the hemi
