1990 w150 no oil pressure
Old 02-18-2018, 07:51 PM
Mr.tillman99's Avatar
Mr.tillman99
Mr.tillman99 is offline
Exclamation 1990 w150 no oil pressure
I have a 1990 power ram 5.2l 318 with 10k miles since the engine was rebuilt i started it up and it has completely no oil pressure so I pulled the valve cover to make sure it was a faulty sensor and still no oil pressure so I pulled the oil pan and checked the oil pump and it's still in good working condition it was replaced when the engine was rebuilt so I checked the shaft and it spins with the engine so I put it all back together with new 5 qts of oil and a new filter and still no oil pressure any ideas???
Old 02-18-2018, 08:31 PM
crazzywolfie's Avatar
crazzywolfie
crazzywolfie is offline
have you checked with a mechanical gauge? when in doubt i always go old school. mechanical oil pressure gauges are cheap and let you see exactly what the oil pressure is doing.
Old 02-18-2018, 08:33 PM
Mr.tillman99
I haven' tried that but if its not getting oil too the rockers what would be the point?
Old 02-18-2018, 09:33 PM
crazzywolfie
with a mechanical gauge you would see if the engine is building oil pressure or not
Old 02-18-2018, 11:32 PM
Mr.tillman99
If it is getting pressure why would the rockers not be getting oil?
Old 02-18-2018, 11:34 PM
Bullyfrog's Avatar
Bullyfrog
Bullyfrog is offline
Your rockers are dry?
Old 02-18-2018, 11:35 PM
Mr.tillman99
Yeah it no oil at all to the rockers on the driver side I will check the passenger side tomorrow which will probably be the same
Old 02-18-2018, 11:39 PM
Bullyfrog's Avatar
Bullyfrog
You check if the pickup tube was clear?
Old 02-18-2018, 11:41 PM
Mr.tillman99
Ya I cleaned it out and blew air through it and I checked the oil pump by putting a Alan bit on a drill and it seems to pump and push just fine
Old 02-18-2018, 11:46 PM
Bullyfrog's Avatar
Bullyfrog
Does it sound like like dry lifters? Check dipstick when its warmed up should be thin and high on it. Old trick for oil pressure problems is put 1 qrt of tranny fluid in.
Quick Reply: 1990 w150 no oil pressure
