01 1500 46re Transmission
Old 02-21-2018, 09:50 PM
Ruleeman's Avatar
Ruleeman
Ruleeman is offline
Default 01 1500 46re Transmission
I've recently had my transmission rebuilt at 145,000 miles. They did the works; all new solenoids, torque converter, and even an upgraded shift kit(shifts rough, can even hear drivetrain slam when in between lights). I now have issues with less than a 1.5 years later(35,000 miles). I drive like a grandma, its a truck not a race car. I hardly tow anything.
I went on a trip right after the transmission was rebuilt and didn't feel confident about the rebuild. I heard a weird drone at 45-50 mph, even got the shop that rebuilt it to ride with me and they swore the noise was "spark knocking" On the rare occasion I have to floor it, the tranny will hold a gear and actually bounce the motor off the rev limiter.
Because of my Job, I've had to relocate to MN for a little while. About a month ago, my truck suddenly would not shift out of 2nd gear. I pulled off at a gas station to check the transmission fluid level and it was good. I pulled back out on the road and it shifted like it should. 2 weeks ago, I got the dreaded P1740 MIL code. Didn't think anything of it so I reset the computer, I lasted about 500 miles until the other morning. I thought because of how cold it was the truck wouldn't shift into OD(No P1740 MIL light yet). After an hour I needed to refuel by restarting the truck it shifted fine again. On the way home, I got the P1740 MIL light again and it locked me out of OD. I pulled off at a gas station to reset the computer and it shifted fine.
I've called the shop that rebuilt the tranny. Unfortunately, I am over their warranty policy by 4,000 miles. They are willing to diagnose the issue for free but I will have to pay for labor and parts. I can't get my truck back to them until Easter weekend. I am nervous I am chasing after a unicorn. What do you guys think it might be?
Old 02-22-2018, 12:53 AM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
The 8pin plugs on the tranny are known to corroded because they get all the gunk from the road. It could be that, a bad sensor, or a bad solenoids. Here is what you could do. Unplug the 8pin connector on top of the trans right behind (towards rear) of the gear selector. I attached a picture of the plug and location. When you do this you will have no electronic functions (it will be like driving a manual) you will have to start out in 1st shift to 2nd when you want and then shift to D (which is 3rd) report back if it shifted.
Quick Reply: 01 1500 46re Transmission
