[5th Gen : 08+]: Losing Anti-freeze
Losing Anti-freeze
2013 Grand Caravan with 3.6 with almost 200k miles
I am losing anti-freeze but I have not start looking for the leak yet. I wanted to ask on here if there any known issue with any of the parts to check for leaks before I go start looking for it or is water pump most likely the culprit?
Thank you
Thank you
I looked all over and I cannot find the leak. It was blowing cold air and the thermostat was replaced then it start blowing warm air again after awhile it blow cold air so I am assuming it water pump.
Is common for a 3.6L water pump to fail over 150K miles?
I rented a pressure tester and found the leak coming from one of the heater Y connector A piece of plastic ...
I went brought an aftermarket one but is there an instruction anywhere on line installing the aftermarket one? I notice one of the connector seem to be a snap on type? How do I remove the old one? Do I need to get a special tool or I squeeze somewhere on the connector itself to release it?
Also the crimps on the factory hose? I just try to cut it off with a cutter or something? It seem to be made of plastic too
https://www.oreillyauto.com/detail/d.../grand-caravan
Thank you
Thank you
I just did this 2 weeks ago on my 2010 SXT 4.0. I just cut out the plastic "Y" and used a 3/4" PEX brass "T" fitting and hose clamps. I also had to get a 5" piece of ordinary 5/8" heater hose to go from the brass "T" to the thermostat. Working great and no evidence of reduced heat output in front or rear. Total cost about $10. Many posts about this on internet and youtube. Seems to be a common problem.
