3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Full vin 1D7HU18D53S217918 01/2003 production date. No tag on rear. Pinion nut loosened and rear is locked. Need info to order replacement differential. Is there any info on door vin tag? Or anywhere? Any help is appreciated. Corey S
Looks like 03 1500 4x4 crew cabs use 9.25 12 bolt rears with 31 splines.
The front axle has a legible tag and reads 3:92
this should be all I need to get price and availability for remanufactered diff.
Hey You,
That’s not a bad idea, been a long time since I set pinion depth and shimmed carrier bearings. Prolly the way to go finance wise as long as the case isn’t too boogered up.
An option may be to just remove the axle from the truck and take it over to a driveline shop. Have them swap the parts in their shop. A mid point cost control which also avoids botching the job by having the pros take care of the shimming and backlash etc.
