Brake pedal/stoplight switch help needed.
Old 03-17-2018, 09:35 PM
NW Redneck's Avatar
NW Redneck
NW Redneck is offline
Question Brake pedal/stoplight switch help needed.
I’m having an issue with my brake pedal not returning all the way causing the brake lights to stay on unless the pedal is pulled up the last 3/4” or so manually. (99 5.9l SLT) I originaly thought it was the brake booster as the seal around the rod coming through the firewall looked pretty bad & the rod was all rusty. Replacing the booster didn’t help. I tried adjusting the length of the rod in the booster that pushes on the master cylinder with no effect. I bled the brakes all the way around putting a full litre of new fluid through the system. There seems to be no adjustment to be made on the stoplight switch. How easy should the pedal move when unhooked from the booster rod? It would move fairly easy by hand but would stay in place wherever it was let go at. I’m wondering if the pedal is not moving freely enough & needs new bushings or if it’s a problem with the master cylinder? Thanks in advance!
Old 03-18-2018, 08:37 AM
JeeperDon's Avatar
JeeperDon
JeeperDon is offline
Hit the pedal pivot point with some WD-40, see if it loosens up a bit.
Old 03-19-2018, 09:10 AM
NW Redneck's Avatar
NW Redneck
I’ve oiled it a couple of times now with no change.
Old 03-19-2018, 03:29 PM
Dodgevity's Avatar
Dodgevity
Dodgevity is online now
I haven't messed with the brake position sensor switch on these trucks, but on most cars the plunger can be adjusted. Is that what you meant by the stoplight switch?
Old 03-20-2018, 12:12 AM
NW Redneck's Avatar
NW Redneck
Yes, its the switch that activates the brake lights. Mine is not adjustable, or at least according to the manual it can only be adjusted once when it’s first installed.
Quick Reply: Brake pedal/stoplight switch help needed.
