Temperature Gauge Inop
Old 03-20-2018, 01:56 PM
C12Creed's Avatar
C12Creed
C12Creed is offline
Default Temperature Gauge Inop
Sensor I found behind alternator.
1997 Dodge Ram 1500 5.2L V8 4x4
The temperature gauge does not start up when the truck is on. Im trying to find any suggestions on whether it may be a thermostat, coolant temp sensor, or sending unit.
Im getting mixed info from google and youtube about which would be the answer. Also,when I bought the coolant temp sensor at Autozone, and looked up the location online (behind alternator, passenger side of engine), the sensor I found looked different than the sensor I bought. The sensor I found had a house-shape head, while the autozone sensor is an oval-shaped head. If anyone could tell me what sensor I found,please do as well.
Thanks!
Old 03-20-2018, 02:14 PM
Your truck has two sensors. The one on the passenger side should be a one-wire connector, and that's the one for the gauge. The other sensor is a two-wire, for the PCM, and sits beside the thermostat housing.
Old 03-20-2018, 02:20 PM
C12Creed's Avatar
C12Creed
C12Creed is offline
So I am assuming the two wire is the one I bought, and the one wire is the one in the picture. Any idea where I can purchase the one wire and its name? Autozone had no parts related that they could find.
Old 03-20-2018, 02:33 PM
Just another coolant temp sensor.
May have to have a chat with your local dodge dealer, to get the correct part number. The parts catalog I have is being really uninformative.
Old 03-20-2018, 02:45 PM
C12Creed's Avatar
C12Creed
C12Creed is offline
Ok,thank you! I'll let you know how it goes. Either by tomorrow if they have it or probably in a week.
Old 03-20-2018, 02:52 PM
If they don't have one, get the part number, and google search the number, someone should have it......
Old 03-20-2018, 09:10 PM
frankie_b_jr's Avatar
frankie_b_jr
frankie_b_jr is offline
Here is a number from the Napa website for the gauge (single wire) sensor.
MPE TS6682SB
Make sure you specify it's for the gauge. When searching for it in most auto parts store so it is listed as "Temperature sensor- gauge". The other (2 wire) is usually listed as "Engine coolant temperature sensor".
Old 03-26-2018, 09:53 AM
C12Creed's Avatar
C12Creed
C12Creed is offline
Thanks for the help everyone! I eventually found that the part you guys are talking about is called Temperature Switch at auto stores. For 10$! Fixed my issue right away!
Old 03-26-2018, 11:33 AM
elreyes8's Avatar
elreyes8
elreyes8 is offline
Hi i have a 98 dodge ram. I cannot find the ECT sensor connector anywhere!! I am talking about the ECT sensor located next to the thermostat housing. Can anyone please help?!
98 ram 1500 5.2
Old 03-26-2018, 03:41 PM
Is it not plugged into the sensor??
It should be around there somewhere. It's part of the harness, so, it has to be close.
Quick Reply: Temperature Gauge Inop
