The dreaded rearend clip
Old 04-20-2018, 06:04 PM
goatman's Avatar
goatman
goatman is offline
Default The dreaded rearend clip
Old 04-20-2018, 06:08 PM
goatman's Avatar
goatman
goatman is offline
Originally Posted by goatman
So found these in my rear end today 94 ram 1500 3.55 there hasn't been any issues with the rear end no noise no chatter can I just replace these and move on or do I have to do a major repair I tow a 55oo lb trailer so I don't need any issues any help would be greatly appreciated.
Old 04-20-2018, 07:51 PM
Received 3,166 Likes on 2,920 Posts
You have the limited slip rear. Rebuild kits are fairly inexpensive, and you can do it without pulling the carrier.
94 is second gen though, so, moving this thread there.
Old 04-20-2018, 08:49 PM
goatman's Avatar
goatman
goatman is offline
Sorry !
Old 04-20-2018, 08:53 PM
Sorry !
No worries.
Old 04-20-2018, 09:51 PM
goatman's Avatar
goatman
goatman is offline
No worries.
So what kit would I look for and how would I do it without pulling the carrier ? just not familiar with the 9.25 Pontiac guy.
Old 04-21-2018, 08:30 AM
Rock auto has the kits, though I think you need to buy the clips separately.... (which makes zero sense to me......) I would suspect that most any parts store could get you the kit you need as well.
Old 04-21-2018, 11:31 AM
goatman's Avatar
goatman
goatman is offline
One last question a friend has a 3.92 carrier and pinion will it work in my housing thanks for your help as I seem to be on my own.
Also he was interested in my 3.55 to swap his 3.92 is that a bad idea thinks he will get better mileage ?
Old 04-21-2018, 03:57 PM
What is he driving? Is your truck 4x4?
Old 04-22-2018, 06:32 AM
goatman's Avatar
goatman
goatman is offline
No they are both 4x2 5.7 45rfe trucks .Ok so I pulled the carrier bearing caps and the axels I still don't see where these came from If they can be changed out without removing the carrier
I can't see it .
Quick Reply: The dreaded rearend clip
