01 Ram 1500 Rear U Bolt Spring Plate Info Needed
Old 04-23-2018, 01:11 AM
hometheaterman's Avatar
hometheaterman
hometheaterman is offline
Default 01 Ram 1500 Rear U Bolt Spring Plate Info Needed
So, I would like to replace the rear lower spring plates that the u-bolts go through on the bottom of the axle for a Chrysler 9.25, but I'm having a really tough time trying to find these. I looked through some online OEM part site and when you click on the ones they list, it says for the Dana 80 which is obviously not what my 1500 has. I tried looking on eBay, but most of the OEM ones I'm seeing say they fit 94-02 2500's and 94-99 1500's. I've yet to find any that say they fit an 01 1500. LMC Truck only lists these for the 2500's as well. Have any of you guys run into this? Does anyone know the part number for the correct ones?
I also need new u-bolts. Any recommendations? I do have an add a leaf in there, so I'll need slightly longer than OEM. I'm really not sure the length, is the best way to just measure from the top to the bottom?
Old 04-23-2018, 02:47 AM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
It's the same axle from 95-01 so my guess if it fits 96-99 it'll for yours. I'd measure your current setup and go an inch longer or take it to a spring shop and they will measure and make them for you in the spot (local shop charges $10 for that)
Old 04-24-2018, 01:44 PM
AtomicDog's Avatar
AtomicDog
AtomicDog is offline
Contact these folks and provide them with information about your truck (year, make, model, etc.) - also best to measure the length and width of your existing U bolts - http://www.springsnthings.com/
I just ordered a new set of U bolts for my truck as I noticed one was broken.
Quick Reply: 01 Ram 1500 Rear U Bolt Spring Plate Info Needed
