i recently bought a 2012 Durango and it does not have the button to start the car. Instead you push the fob inside the hole and twist. I don’t think this is factory. Anybody know how expensive it can run?
Isn't the removable button the backup if the key doesn't get picked up by the sensors? Pop the cover off and use the key?
roog
Yes, if the vehicle came with keyless start. Some of the more basic models as well as older models came with the tip start with required the fob be inserted and turned. I know push button was available in the Durango by 2012, but I'm not sure if it was standard on all models or not.
-Rod
Ah, thought they all did. Our 2011 Crew had it too.
