Rough Idle, No Power from Take off
Old 05-16-2018, 03:11 PM
Steve M's Avatar
Steve M
Steve M is offline
Question Rough Idle, No Power from Take off
1999 Dodge Dakota SLT 3.9L V6
Let me list what I have done then give the issue.
Replaced so far:
Distributor Cap
Distributor Rotor
Spark Plugs
Spark Plug Harnesses
Fuel Pump
Throttle Position Sensor
Manifold Absolute Pressure Sensor
Camshaft Position Sensor
Check Engine Codes since replacing those:
P0201
P0203
P0205
P0300
P0301
P0303
P0305
I know they deal with misfires in 1, 3, and 5 cylinders but for the life of me I can't narrow down the issue.
Here is what my truck is doing, from take off there is no power, she idles rough or stalls out. When driving, I get her up to above 40 and she will seem fine until I hit a hill then she bogs down. Overdrive doesn't kick in but today she slightly kicked in allowing me to maintain between 40 and 50 mph. Then if I come to a complete stop and go, again no power. I'm tired of guessing and even worse I'm tired of thinking I have the problem found and still not fixed. This is my baby, my fixer-upper that I bought outright to give me something to do since I'm disabled. So far I have sunk $3,000 into her and I'm ready to quit unless I find the problem real soon.
Thanks for any help.
Old 05-16-2018, 03:44 PM
Steve M's Avatar
Steve M
Steve M is offline
I did a little more digging and it is possible that the Camshaft Position Sensor I installed is bad from the start so going to replace that tomorrow and see how things are then. I'll check back in after that to give an update.
Old 05-16-2018, 05:45 PM
magnethead's Avatar
magnethead
magnethead is offline
Hmm, did you google those engine codes?
You have a bad power circuit to the injectors causing an erratic firing sequence and thus misfires.
Old 05-16-2018, 05:49 PM
magnethead's Avatar
magnethead
Also, checking fuel sync (requires Snap-On MODUS or a DRB3) will verify if the cam and crank sensors are valid.
Old 05-17-2018, 08:57 AM
n84434's Avatar
n84434
n84434 is offline
It would be interesting to see what the fuel trims are doing. If your scanner can read real time data, pull up the Short term and Long Term fuel trims and see what kind of numbers you're getting. A healthy engine will oscillate between -4.0% and +4.0%.
Old 05-17-2018, 02:37 PM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Double check the connectors at the PCM, it would be connector 2.
Old 05-17-2018, 03:09 PM
hidden1's Avatar
hidden1
hidden1 is offline
Yea ,check crank position sensor.
It wont hurt too see that you IAC isnt stopped up w gunk .
Test the 3 Injectors too,including wiring/signal.
interesting that its 1,3 an 5..all on same side ,
also check plug wires.
Old 05-17-2018, 11:15 PM
magnethead's Avatar
magnethead
interesting that its 1,3 an 5..all on same side.
Each bank of injectors share a power source, with ground being pulsed by the PCM.
Check connector 2 as advised, and check the power supply wire. The wire runs from the ASD relay in the PDC, same as fuel pump and ignition coil. Should have constant voltage when running.
Old 05-18-2018, 12:50 AM
Steve M's Avatar
Steve M
Steve M is offline
Thanks for the input. I just replaced the crankshaft position sensor again but that didn't solve the issue. I'll check at the PCM. I'll check my IAC as well, the wires right where the fuel injectors connect is bare, I did a temp fix by using some window washer tubing and zip tying those on. I will use my ohmmeter to make sure the wire isn't failing.
Old 05-18-2018, 09:29 AM
hidden1's Avatar
hidden1
hidden1 is offline
I would cut back that wire an put in new connector then test ohms .An ohms test all wires as you wiggle them.
Also probe them as running to test for correct reading..
Quick Reply: Rough Idle, No Power from Take off
