What Am I Looking At Here? - A/C & Vacuum Line T/S
Old 05-19-2018, 02:36 PM
YourMileageMayVary's Avatar
YourMileageMayVary
YourMileageMayVary is offline
Default What Am I Looking At Here? - A/C & Vacuum Line T/S
As the title states, I’m troubleshooting the infamous A/C vent to defrost problem.
Looked underneath the dash while cycling the climate control *****. No doors move in any of the settings.
Next step is to look at the check valves.
So, after reading the appropriate manuals, there are supposed to be two check valves in the vacuum lines associated with climate control: one nearest the engine on the passenger side and one downstream of that, at a T-junction
Instead of what I thought I’d find, I found what was pictured. I’m not a Ram expert, but Spidey Sense says this isn’t t right.
Old 05-19-2018, 04:11 PM
Torxhead's Avatar
Torxhead
Torxhead is offline
I once had an issue similar to yours, here is the post with pics, maybe it will help:https://dodgeforum.com/forum/2nd-gen...eeds-help.html
Old 05-19-2018, 05:42 PM
YourMileageMayVary
Appreciate the link. Helped me see what right looks like.
FWIW, unless that ginormous thing in line is, itself, a check valve, I'm not really sure what it is. My sense is that it's supposed to be connected to the vacuum reservoir; I have yet to remove the cowl to check (due to weather).
Curious if anybody here has seen this before or has this device in their engine bay.
Old 05-19-2018, 06:15 PM
It's a checkvalve/minor vacuum reservoir. Probably got put on by a previous owner to deal with wild vents.
Old 05-19-2018, 07:53 PM
YourMileageMayVary
Interesting. Clearly not stock to this vehicle.
That would be consistent with other things I've find in the truck since I've had it.
Wondering if that small line at the far end even connects to anything now...
Old 05-19-2018, 10:05 PM
If you vents aren't working, likely that one was supposed to go to the HVAC control head.
Old 05-20-2018, 10:54 AM
Moparite's Avatar
Moparite
Moparite is offline
Here is the vac line diagram.
You can get the right check valves from napa.
https://www.napaonline.com/en/p/NDP7301349
Old 05-20-2018, 01:19 PM
YourMileageMayVary
Moparite,
Thanks for the drawing. This is the diagram that actually caused me the greatest confusion between what's actually installed in my truck, as seen in the photo in the OP, and what's supposed to be there. On the basis of this diagram, I was about to go in and change out the downstream check valve; I stopped when I noted the reality/diagram mismatch.
Another day of rain is keeping me from pulling the cowl and looking at what's going on there.
@HeyYou, if that mini reservoir/check valve assembly was supposed to help with wild vents, it wasn't working well at all. Have had the wild vent issue since I had the truck, but only recently did the blower doors stop working altogether.
Old 05-20-2018, 01:30 PM
Check it and see if the check valve in it has failed.
Old 05-20-2018, 09:12 PM
2bit's Avatar
2bit
2bit is offline
You possibly have other vacuum leaks. After market PCV valves sometimes flow too much air and are an undetectable vacuum leak. Use a Mopar PCV valve. Your cruise control and 4wd could be leaking or your plenum gasket. Start with fixing the broken line you found and test the vacuum reservoir for leakage.
Quick Reply: What Am I Looking At Here? - A/C & Vacuum Line T/S
