Differential question
I had a dirrerential fluid leak an after replacing cover,new rtv,set up time, an tightening bolts 2nd time to torque spects 1 top left bolt busted.
Its been driven an no leaks.
Will this be ok for a while till i can get to it later since all bolts around it are at 30ft lbs an its at top corner ?
Which method works best..a easy out or left handed drill bit ?
