Compensation for straight pipe
Old 05-23-2018, 11:18 AM
Jmikk's Avatar
Jmikk
Jmikk is offline
Default Compensation for straight pipe
Hey all, i have this thing where my 5.9 ram has to be straight piped i love that roar. How do I bring my miles per gallon back up? Cold air intake of course cause the truck is exhaling and not really inhaling but beyond that what can I do to get back to that happy place at 12-13 and not 9-10.
Old 05-23-2018, 12:02 PM
V65Ozzie's Avatar
V65Ozzie
V65Ozzie is offline
Relatively speaking, deleting the muffler shouldn't have an effect on gas mileage. Now, if you have pulled the cat....that's a different ball game. Do you rev it at lights? That has a large impact on gas mileage.....
Old 05-23-2018, 12:26 PM
Jmikk's Avatar
Jmikk
Jmikk is offline
cat is still there I just can’t keep my foot out of it all the time. Trying to just even it all out so I can have my sound and enjoy it too
Old 05-23-2018, 03:04 PM
What year is your truck? Still have the pre-cat O2 sensor?
Old 05-23-2018, 04:10 PM
Jmikk's Avatar
Jmikk
Jmikk is offline
2001 1500 5.9 cat in tact with pre and post sensors in place and plugged in
Old 05-23-2018, 11:25 PM
Aero540t's Avatar
Aero540t
Aero540t is offline
I think you answered your own question
Old 05-24-2018, 01:28 AM
Ramman18's Avatar
Ramman18
Ramman18 is offline
Exactly what I was going to say.
Old 05-24-2018, 09:01 AM
Jmikk's Avatar
Jmikk
Jmikk is offline
i mean it’s part of it but there’s got to e a way that I can drove this way and see higher numbers, with a glass pack driving the way I am I was seeing 13 and that’s still a straight through pipe so I don’t understand why with the same habits and no muffler it’s gone downhill.
Old 05-24-2018, 11:27 AM
Ramman18's Avatar
Ramman18
Ramman18 is offline
So you're not really straight piped? Way I think of straight pipes are manifold to pipe down each side with maybe an x or H pipe for resonance but true duals.
If you have factory y-pipe and cat with just no muffler, I would suspect something else is causing your mpgs. I have Magniflow ypipe with glass pack and my power went up and mpgs stayed 12-13 city.
Old 05-24-2018, 12:55 PM
PR1AWRet's Avatar
PR1AWRet
PR1AWRet is offline
Unless your cats are plugged (literally) up they offer very little resistance. If your cats are unplugged (electrically) your system (OBD2) will stay in open loop mode and uses the preset maps in the computer. When these maps are used, it throws more fuel into the mix to keep it running smoothy until it gets warmed up and other parameters are met. Like a choke on carburetor, keeps it running rich until warmed up and uses a lot of gas. If ran this way (OBD2) for extended periods it will clog the cats reducing power. Haven't researched, if you can cut the aftercat O2 sensor out of the computer parameters then running without cats is no problem and will go into closed loop mode. It'll just pollute a bit more.
Quick Reply: Compensation for straight pipe
