Coils/Springs
05-24-2018, 09:30 AM
on
Coils/Springs
Do you need a coil/spring collapser to change out the springs/Coils in a 2002 dodge 2500 v10?
05-24-2018, 11:22 AM
No. You can support the front frame rails, then jack up on one side of the axle until the other side comes out. Installing lift coils it sure helps to have a compressor. You can also remove one end of the track bar and the sway bar. These all aid in flex.
