Front driveshaft rebuildable?
Old 05-24-2018, 10:29 PM
Blue Rango's Avatar
Blue Rango
Blue Rango is offline
Default Front driveshaft rebuildable?
Is the forward end of the front driveshaft rebuildable? This was causing my vibration upon acceleration, and the shop says it's not rebuildable and has to be replaced at a cost of $854. Seems kind of crazy that a person would have to replace the whole shaft Everytime the rubber wears out.
​​out. Is this correct or can the rubber be replaced?
​​​​​​Thanks
Old 05-24-2018, 10:37 PM
Pspklutch's Avatar
Pspklutch
Pspklutch is offline
I'm not sure but it may help others answer if you're a little more specific with your post. 4.7's were mated to entirely different transmissions than the 5.2 or 5.9 and there were also multiple transfer case options. All of these can change overall length and thus have a different driveshaft. So yours could be a completely different shaft than what's in my Durango, for example
Old 05-24-2018, 10:59 PM
Blue Rango's Avatar
Blue Rango
I have the 4.7 in mine. I can't get the pics to upload so will try them tomorrow. The end with the bad rubber is round and has several bolts holding 2 plates together.
Old 05-25-2018, 08:15 AM
Pspklutch's Avatar
Pspklutch
That should help. Definitely a different driveshaft than mine. Looks like a CV joint on that end. Mine is a double cardon U Joint. Just wait for someone to chime in. Wish I could help but I have no info on those.
Old 05-25-2018, 09:03 AM
JeeperDon's Avatar
JeeperDon
JeeperDon is offline
Yes, the CV end is rebuildable. That shaft under the rubber boot has a splined end. Search an auto parts site and you'll see kits for just that CV end.
Old 05-25-2018, 09:27 AM
primem's Avatar
primem
primem is offline
shop around for a price for the driveshaft...depending on your year, you can get then for 3-400$. at rockauto..install it yourself and save all the shop labour of having them rebuild the old one.
Old 05-25-2018, 01:39 PM
Blue Rango's Avatar
Blue Rango
Thanks everyone. I was quoted $854 to replace the shaft and was told it's NOT rebuildable.
​​​​​​I will start looking for a replacement part
Old 05-25-2018, 07:18 PM
JeeperDon's Avatar
JeeperDon
Originally Posted by Blue Rango
... was told it's NOT rebuildable...
It is rebuildable. Here is the part. Look for a new mechanic too. Shops tell you things they don't want to do are 'not possible' so they just get more money quicker selling you more than you need. Since you are not doing this yourself though, you're at their (lack of) mercy. If there is a driveshaft shop in your town, and you pull the shaft and hand it to them to fix, for sure it will be less than $800+.
Old 05-25-2018, 09:31 PM
Blue Rango's Avatar
Blue Rango
Thanks so much, JeeperDon. I will order the kit and take the shaft to a driveshaft shop. I have it out of my Durango now.
​​​​​​Hope you and everyone here has a good Memorial Day
Old 05-25-2018, 10:37 PM
JeeperDon's Avatar
JeeperDon
That kit I posted was just an example. O'Reilly's is my local shop. A drive shaft shop could get the part too, would probably prefer to. Just take them the dead one and see what they offer.
Quick Reply: Front driveshaft rebuildable?
