brakes and ABS
new pads and new rotors, new shoes, wheel cylinders and drums and master cylinder and flushed out old fluid with a pressure bleeder. I did all of this because the brakes were soft and I can not stop in 150 feet at 25 MPH, even in panic it just slows down to a slow stop. No ABS action and no lights. I did take it to the local parts store and they read all the codes and nothing. I am at a loss. and the ABS fuse is OK . No leaks anywhere and low pressure at the rear wheels.
"Low pressure at the rear wheels." There is a proportioning valve in the system. Drum brakes are self energizing and use a lower pressure than a disk brake.
There could be air in the system even with pressure bleeding. You may need to cycle the ABS system while bleeding it. A DRB is required.
It could also be the flexible lines, all 3 of them.
The only thing that has not been changed out are the flex lines and combination valve, even after adjusting the rear brakes pedal travel is close to the floor, I have even set the E brake and checked the travel and still goes about the same distance. I just bought this truck for a fishing truck and found the brakes to be acting this way and this is why I have done all of this work. I am about ready to by pass the ABS all together, because all I am seeing is bad problems with it for other Dakota owners.
The ABS system is not the problem. You have a BASE brake system problem - the hydraulics.
That's also why there is no ABS warning light.
The ABS kicks in to prevent a wheel from locking up. It sounds as if your braking is so poor that that is not happening.
Check those lines and bleed the entire system - using a DRB to cycle the ABS.
