Dodge Magnum The Dodge Magnum, the wagon that made wagons cool. The unique look of the Dodge Magnum makes any trim level, from SE to SRT-8, an absolute head turner.
pulsating feeling when in idle
Old 06-17-2018, 04:11 AM
MagnumHemi's Avatar
MagnumHemi
MagnumHemi is offline
Default pulsating feeling when in idle
05' Magnum RT / pulsating feeling when in idle. No check engine light. RPM is normal, needle does not fluctuate. Replaced sparkplugs+wires/pcv valve/clean out filter+maf sensor/oil chg
Old 06-19-2018, 12:30 AM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
Moved to correct forum.
It's not being caused by the a/c compressor cycling, is it?
Old 06-19-2018, 01:36 AM
MagnumHemi's Avatar
MagnumHemi
Actually, with the ac on, it makes the car idle better. For example, ghost riding the car with me in it, no acceleration just gliding, you can feel it pulsating. Especially if your head is on the head rest like your kid kicking the driver seat. Its not a bad idle to the point it will stall.
Old 06-20-2018, 11:54 PM
draftingmonkey's Avatar
draftingmonkey
draftingmonkey is offline
Have had the same occasional "rough idle" with my Magnum since day one. I think it is just a Hemi thing. Have had no issues caused by it in the 13 years I've owned the car. Also, remember with the A/C on the computer notches up the idle just a bit while stopped.
Old 06-21-2018, 01:18 AM
MagnumHemi's Avatar
MagnumHemi
I was hoping that would be the case because its a hemi and i read a few forums and said the same thing. I was going to replace the egr valve because i never replaced it but the symtoms of a bad egr is literally your car stalls. I have a few neighbors that owns hemi,srt8. Ill go ask them if they have the same issue...
Quick Reply: pulsating feeling when in idle
