Factory intake hose replacement.
Old 06-19-2018, 02:21 PM
TheLittleTankThatCould's Avatar
TheLittleTankThatCould is offline
Default Factory intake hose replacement.
Hello, I have a 1990 Dakota sport and the plastic feeder hose that connects to the air breather has cracked resulting in a messy idle. I look for a used replacement for 2 years, found a slightly newer dakota sport v6 with one that will fit, but now, as I was going to attach it I noticed it does not have an opening for what appears to be the ecu. My question is, does the ecu need to be connected to the air intake? Can I cap it off and run my new plastic hose? And why was it done in the first place?
thanks,
Old 06-19-2018, 02:39 PM
RalphP's Avatar
RalphP
RalphP is offline
The plastic feeder hose that connects to the air breather won't cause a messy idle; it ducts the cooler air from in front of the fender in, yes, but you should still have a good idle.
You can try running the ECU with it off; that was there to force cooling. You may notice the humpback on the slightly newer sport V6's ECU; that avoided using the air intake as a cool air source.
RwP
Old 06-19-2018, 02:56 PM
Thank you very much.
Old 06-19-2018, 03:41 PM
RalphP's Avatar
RalphP
RalphP is offline
Let me now ask what you mean by a "messy idle".
RwP
Old 06-19-2018, 03:51 PM
For sure. Initially when it cracked it would idle high, 1300rpm or so. After I heat taped the cracks it went back down to 700 or so.
Old 06-19-2018, 04:20 PM
RalphP's Avatar
RalphP
RalphP is offline
That's probably more you juggling the bad vacuum lines. I've had to replace all of mine on my 1988; try running the vacuum lines and fixing all of them.
RwP
Old 06-19-2018, 04:27 PM
Alright I will take a close look at them. Thank you again
Old 06-19-2018, 05:45 PM
Is the air ducted over the ECU just for cooling? Or is the ECU also measuring airflow past it??? (Was always curious about that......)
Old 06-19-2018, 06:18 PM
RalphP's Avatar
RalphP
RalphP is offline
There's no inlet air temp sensor there, no.
I've always presumed it was for a venturi effect cooling; as the motor sucks air, it'll suck some out of the ECU causing it to intake around it (due to the vents to the back).
I dunno; could just be some Veep at ChryslerCorp had a relative with a helladeal on the Ts they use *grins*
RwP
Quick Reply: Factory intake hose replacement.
