Locking the Rear Diff
Old 06-19-2018, 07:41 PM
19dhyer's Avatar
19dhyer
19dhyer is offline
Default Locking the Rear Diff
Hey there. 2006 Dodge dakota SLT 4.7L V8. I just had a question. My truck has the elctronically changing transfer case for 2WD to 4WD Hi and 4WD Lock. My truck also has an open Rear Differential. When you shift into 4WD it locks the rear diff. Is there any way to lock the rear diff without engaging 4WD? I expect there to be a wire that locks the rear diff and if there is, is there a way to splice into it and wire up a button to engage it? Main reason is for Burnouts.(Duh!) Ya I know it wears tires and all that but who doesnt love a good burnout. Im just stuck with 1 tire fire. Once again just wondering if there is a way to lock the rear diff and keep it in RWD.
Old 06-19-2018, 07:49 PM
daktwos's Avatar
daktwos
daktwos is offline
Dakota's were never equipped with ARB air locker diffs that I know of to allow you to do that.The poor man's posi in the old days was to weld the axles.Better yet find a salvage yard Dakota with a posi rear end.
Old 06-19-2018, 08:25 PM
19dhyer's Avatar
19dhyer
19dhyer is offline
Yeah i know. But its electronically controlled. So i figure there is a specific wire which locks it. Just wondering if anyone knows of or if there is way to program the ecu to do it.
Old 06-19-2018, 09:57 PM
daktwos's Avatar
daktwos
daktwos is offline
Believe that is for rear and not for posi engagement.
Old 06-20-2018, 01:55 AM
19dhyer's Avatar
19dhyer
19dhyer is offline
thats what im asking. Is there a wire, and if so which one, that locks the rear diff.
Old 06-20-2018, 02:13 AM
daktwos's Avatar
daktwos
daktwos is offline
I meant to say abs sensor.
Old 06-20-2018, 07:52 AM
dakotaff's Avatar
dakotaff
dakotaff is offline
No, there is no wire to give you a locked rear diff.
Read the threads below, you can swap one in if you'd like, but it's definitely not as easy as splicing wires together.
There are tons of threads here about differentials, these are only a few.
https://dodgeforum.com/forum/3rd-gen...ge-dakota.html
https://dodgeforum.com/forum/3rd-gen...entials-2.html
https://dodgeforum.com/forum/3rd-gen...-locker-2.html
https://dodgeforum.com/forum/3rd-gen...ed-slip-2.html
https://dodgeforum.com/forum/3rd-gen...slip-diff.html
https://dodgeforum.com/forum/3rd-gen...t-project.html
Old 06-21-2018, 12:27 AM
19dhyer's Avatar
19dhyer
19dhyer is offline
then what locks the rear diff?
Old 06-21-2018, 01:57 PM
dakotaff's Avatar
dakotaff
dakotaff is offline
Installing a rear locking differential.
Old 06-21-2018, 03:11 PM
19dhyer's Avatar
19dhyer
19dhyer is offline
no the rear diff locks, just only in 4WD mode
Quick Reply: Locking the Rear Diff
