[3rd Gen : 96-00]: 99 grand caravan tranny issues
Did some reading. Saw alot of mention about going into limp mode. Does this meen falling on its face ? When I start to accelerate,it just falls on its face almost like I am applying the breaks. And then sometimes,rarely,it will start to accelerate again,only to fall on its face again. Reverse works fine,just forward is giving me this issue. Going to try to find the 3 wire splice that I read about and see if that is the problem as far as it going into limp mode.
Also,I friend has an 02 sebring that he is scrapping out,and swears that the tranny is the same,or universal and will work in my 99 caravan. I am having my doubts.The most important being that it will not interface with the computer. And the top two bolts on the sebring are slightly different,but it has two sets of holes on top of the bell housing.
Any advice on my problems would be greatly appreciated. Or a note telling me that I am on the right track.
I could not find anything explaining exactly what limp mode is and how the vehicle acts when it goes into limp mode.
Thanks in advance...
No,My buddy with a scan tool is working and can only get by to visit me on the weekends.
I am new to owning a dodge. I know on my GM's there were ways to pull codes without a scan tool.
Is there a way to do this on a dodge vehicle ?
I have only owned the vehicle for a month now. And the previous owner told me that they had a used tranny put in it not long ago. And a new one before that.
I have heard since that these vehicles have alot of transmission problems...not sure if that is true.
Also,I have another friend that is parting out an02 sebring with a 2.7 motor in it. He is trying to tell me that the transmissions are universal. I was a heavy equipment mechanic back in the 80s,and find this hard to believe that transmissions 3 years apart would be universal. I am thinking that he may be just trying to push a tranny off on me and make a buck. but if this is true,I would definitely be up to giving it a try.
My mechanic friend that I mentioned with the scanner said that there would be computer issues with a tranny swap like that mentioned
Any 96-06 (IIRC) trans will work however. Later ones have stronger internals than the older ones.
Have you tried simply changing the fluid/filter?
