3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
please help me I just bought this truck and it won’t start,I have spark and my fuel pressure is at 55psi the codes coming up are P0113,p0700 and p2106 I don’t think any of these would cause the no start.any help would be greatly appreciated
P0113 IAT circuit high. This *could* cause a no-start, as the PCM will run the engine quite lean...... may not be a burnable mixture when the engine is cold.
p2106 means the pcm is limiting throttle opening, due to another failure elsewhere. (P0113 perhaps......)
Replace the IAT sensor. Clear codes, see if it starts.
Timing is controlled by the computer, and is not adjustable at all. If you are getting good spark, and have fuel pressure, check and see if you are getting injector pulse. (noid light, local parts store should be able to rent you one.)
