Hi, I have a 2001 Dodge ram 4x4 quad cab with the 5.9.
I don't plan on putting the shield back on. I don't know why someone would think it was a good idea to put something on that risks damaging the motor or heads because of rust in the plug and it breaking off and now I'm sure when I am prying,pulling,beating that thing off there will be all kinds of crap going in the hole. Bad Idea. Just so you don't hurt the wires ?
I had trouble with the heat shields. Hours of trouble. People say the plugs are stripped out and things like that. It is more likely that the socket can't get on the plug and it seems like it is stripped. The heat shield may have rusted and got thicker because of the rust. It might even be bent.
What I did was to use a dremel cutting disc to cut an additional line down the heat shield. There is already one seam on each one. (they are a rolled piece of sheet metal and not welded at the joint) It is nice to cut near the existing gap and pull hard with pliers. Wiggling is the best thing. Some came out easily and others were a lot of work. You can't cut all the way down since the bottom of the heat shield is pressed in. On some I had to twist the metal to break it free from the rust bond.
Another option is a thin wall spark plug socket. (normally 12 point) That might help, I talked to a mechanic at a shop that said he would just use a 12 point thin wall socket to remove it. I tried to find one of those and I couldn't. (just at local stores that is, I didn't look online)
Once you have it remove, don't take out the plug. I put a vacuum cleaner on it (shop vac). That helped. Then I used my air compressor (you could use canned air) to blow out the rest of the rust and stuff that gathers in there. It seems to me that purpose of the heat shield is to provide a place for stuff to gather. Any time I change plugs on any vehicle, I like to vacuum it then blow it out with the compressor. You don't want to make things worst and getting rust and dirt in your cylinder can definitely make things much worst.
