3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Pump up the brakes so they are good and tight, try and turn a wheel. If it is really stiff, crack open the bleeder valve. If it is not easy, replace the soft lines.
it's both sides , really don't think it's the hoses both at one time ,, odds would be very high
It's a process of elimination. While odds are against both lines failing at the same time, it isn't unheard of. Need to check it, to eliminate it as a possibility.
