[5th Gen : 08+]: Ok I really screwed up help..
Old 07-15-2018, 02:05 PM
Bob Green's Avatar
Bob Green
Bob Green is offline
Default Ok I really screwed up help..
So i really f'd up what should have been a simple shock absorber change is now my current nightmare.
I got the bottom bolt out piece of cake. Trying to get the top bolt out, I ended up stripped the nut. So I decided to remove the bracket that holds the shock absorber on.The 2 inside bolts came out fine. The 2 outside bolts both broke off. I've tried drilling them out but hours later I'm no where close. SO I"m giving up and I want to take to a local shop.
Here's my couple of questions?
Can I drive about 10 miles without a shock absorber on the rear driver side?
OR should I install the bracket back with just the 2 bolts and drive it in?
If they cant get the bolts out, do you think they can just weld the bracket in place?
Thanks!!!
By the way its a 2010 Dodge Grand Caravan 4.0
Old 07-22-2018, 07:44 AM
wrenching40plus's Avatar
wrenching40plus
wrenching40plus is offline
you have to make that decision yourself... in any case go when traffic is minimal and avoid the potholes!
Old 07-22-2018, 01:07 PM
primem's Avatar
primem
primem is offline
would have to see the suspension set up. if the shock helps locate the axle...the answer is a definite no. you have a trailing arm, track bar?
Old 07-24-2018, 09:18 AM
wrenching40plus
Good point... if Bob had meant front, I assumed he would have been referring to a strut. .
Quick Reply: [5th Gen : 08+]: Ok I really screwed up help..
