Second check valve location
Would anyone know the location of a second check valve on our vans. Mine is 01 5.2. There is thread in the 2nd generation ram truck forum called "Wild vent workaroud". Moparite mentions there are two vacuum control valves one on the intake and one near the vacuum reservoir. I could not find the one near the reservoir. My question is do the vans have the second.check valve? Thanks in advance for the help.
SteveR thanks for responding to the problem. I believe, I found the second check valve for our vans. I will check mine to tomorrow to see if the location is correct for mine. This video may help someone having this problem with hvac vents on the vans. The video portion for our vans starts at 11:40 mark:
SteveR thanks for responding to the problem. I believe, I found the second check valve for our vans. I will check mine to tomorrow to see if the location is correct for mine. This video may help someone having this problem with hvac vents on the vans. The video portion for our vans starts at 11:40 mark:https://www.youtube.com/watch?v=0ayGTFR9gHs
I have not checked the second check valve located behind HVAC controls yet. I waiting till I receive the a part from mopar that will correct the default problem permanently. The part is for this http://dodgeram.info/tsb/1996/24-01-96a.htm. The part will be added to the HVAC vacuum line.
The new part is not like the old small check valve here is the link:https://www.mymoparparts.com/oem-par...-check-4677204. I sent them my vin number to mopar and they tried to tell me the part will not work. I call a friend in that works for the Dodge parts dept. and asked him to see if the TSB is applicable to the 01 vans a he told it was. In fact he said that they would install it for 110 dollars.I would let them do it if I still lived in Weatherford Tx. I am in New Mexico now.
also that serves as a small reservoir is my guess. Otherwise if it was strictly a check valve, I can't see why the old one would work except for maybe modifying the tubing just so it can connect.
