2003 Ram 1500
Thanks Ramman18! Its a 4.7L V8. The only reason I ask is because recently towing my trailer the radcap blew off. I don’t know if it was due to a faulty cap or because the t-stat was stuck open.. I haven’t pulled anything since but ran it and no issues. I have read some threads talking about a head leaking into the cooling system causing pressure. Didn’t know if excessive bubbles would be a sign of that or not..
And I have no clue how this ended up in the 2nd gen thread lol
Thanks you again for your thoughts!
And I have no clue how this ended up in the 3rd gen thread lol
You are in the 2nd gen section (94-01) your truck is a 3rd gen (02-08). The bubbles really isn't a way to tell. Any smoke coming from the exhaust? You can have the coolant tested to see if it is a head gasket (really cheap to do). If it's bad enough sometimes you can pull the plugs and see antifreeze on the plug. Or if you have a scope can look into the cylinder
So no smoke even when starting... what places can test the coolant?
Thanks for the help!
