Will this wheel fit in 2008 1500?
Old 08-12-2018, 11:00 AM
ramitup's Avatar
ramitup
ramitup is offline
Default Will this wheel fit in 2008 1500?
Hello,
just wondering if anybody has tried the 2009-2016 20" wheels on a 2008 1500 ram. Wanting to buy these for my 08 1500 but not sure if they will fit based on bolt pattern.
Old 08-12-2018, 01:42 PM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
Any wheel from 1994-2018 will fit if it came off of your ram model (1500, 2500, etc). The only thing you have to look out for is caliper size. But since those are 20s they will fit
Old 08-12-2018, 04:02 PM
Chet Ubetcha's Avatar
Chet Ubetcha
Chet Ubetcha is offline
3rd Gen Ram Moderator
5 x 5.5 -- it will fit. As said, the bolt pattern has been the same since the 2nd gen (not sure if 5th gen follow suit, or not). I've seen daisies on 2nd gens before, as well. You are restricted to minimum 17" wheels by the brake calipers. Since those are stock wheels, you shouldn't have a problem with backspacing and rubbing unless you attempt some stupid-large and wide tires.
Old 08-12-2018, 06:58 PM
HemiLonestar's Avatar
HemiLonestar
HemiLonestar is offline
They will fit just fine, I had a set of those on my 03 before I went to better looking sport wheels (still have the set of you're interested). Just make sure you use your lug nuts, some point during the 4th gen run they went to different thread lug that isn't retrofittable.
Old 08-12-2018, 08:52 PM
MoparFanatic21
5th gen is six lugnuts or tire
Nice truck! What does it say under the 1500
Old 08-12-2018, 09:11 PM
Lonestar.
Old 08-13-2018, 04:38 AM
Chet Ubetcha
Good to know about the 5th gen lug pattern. Thanks!
Old 08-13-2018, 11:45 AM
ramitup's Avatar
ramitup
ramitup is offline
Thanks all. Got the wheels and they look great!
Old 08-13-2018, 12:23 PM
HemiLonestar
Yeah the 19's have 6 lug, someone at work got one.
Quick Reply: Will this wheel fit in 2008 1500?
