Front Right Caliper Sticking
Old 08-17-2018, 03:51 PM
Jaw91097's Avatar
Jaw91097
Jaw91097 is offline
Default Front Right Caliper Sticking
So I've replaced pads, rotors, and calipers up front, and after that the front right brake was still dragging. I let it be for a month because I didn't have the time to mess with that issue, as it was a smaller issue at the time, but I checked them again, put another set of new pads in, and its still dragging that one caliper. I have no rear brakes, they are snipped and crimped at the master. I don't care about that, I care about why my passenger caliper is dragging all the time. Its super hot compared to the driver side, and looks like there is a lot more wear on the brand new rotor. Why would this be happening?
Old 08-17-2018, 05:42 PM
fj5gtx's Avatar
fj5gtx
fj5gtx is offline
did you replace the soft/hard line? sometimes they close off and cause issues... they're not expensive, but getting it off the hardline can cause you a domino effect of replacing hard lines. Lots of penetrating oil will help.
Old 08-17-2018, 06:07 PM
primem's Avatar
primem
primem is offline
+1. to test it do this...
have someone apply and release the brake. as soon as the pedal is released, crack the bleeder screw on the caliper...if fluid spurts out , the flex line is the problem. if the flex line was ok, the fluid would just drip out.
Old 08-17-2018, 07:38 PM
Torxhead's Avatar
Torxhead
Torxhead is offline
I once had one of those flexible brake hoses get blocked up. It seems that they come apart on the inside, and will even act like a check valve allowing only one way flow. It turned my brake rotor blue.
Old 08-17-2018, 10:17 PM
Shadow_Death's Avatar
Shadow_Death
Shadow_Death is offline
Don't forget to grease up your guide pins too. Mine were all gunked up with dirt and grime in the grease so instead of reusing the old ones I bought new ones and greased those up. That helped fix my dragging brakes.
Old 08-18-2018, 09:18 AM
Moparite's Avatar
Moparite
Moparite is offline
X2! This will cause the caliper to stay in one position
Old 08-18-2018, 10:35 AM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
Not to much grease! To much creates a vacuum and it's like not putting any grease on them.
Old 08-18-2018, 11:10 AM
fj5gtx's Avatar
fj5gtx
fj5gtx is offline
What I've found with the 2500 calipers, is that the caliper rusts and squeezes the rubber bushing that the pin slides through - causing it to stick. So I pull the rubber bushings and clean then use brake grease on the holes (napa sli-glyde), then put the bushing back in... then sli-glyde the pins. If I don't do that, I have binding going on within a year or so.
But that is probably not his problem because his calipers are new, my $ is on the soft brake lines.
Old 08-18-2018, 11:43 AM
Jaw91097's Avatar
Jaw91097
Jaw91097 is offline
Alright, I'll replace that line on payday next weekend and let you guys know. Thanks!
Old 08-18-2018, 11:54 AM
Jaw91097's Avatar
Jaw91097
Jaw91097 is offline
Also this is not my video, disclaimer, but this is most likely my problem I think:
Quick Reply: Front Right Caliper Sticking
