Rear Brake Lockup, Help Please!
2001 Dakota, 4.7l, Auto trans, 2WD, Quad Cab, RWABS, 330K miles. Been struggling with the left rear wheel locking up. Had a used rear axle installed due to bearings. All brake parts were transferred since I have the 11" brakes. Maybe coincidence, but I've had the left rear wheel locking up since roughly the same time. Since then I've replaced all components (new) having to do with the rear brakes (flex line, wheel cyl., shoes, hardware, master cyl.). The ABS components (control module, metering valve, RWAL valve, RW speed sensor) were replaced, all second hand components. The metering valve was opened up and cleaned. The system has been bled numerous times. Brakes adjusted numerous times. Backed off the E-brake to take it out of the mix. I'm going to kill myself or someone. Really at a loss. Took it to the garage, without stating what I replaced, and he later listed every component I replaced new, and had no idea as to cause. Really discouraged, as I love this truck.
This may sound strange buy try a few different bleeding sequences such as bleed the front first then the back see what happens if still problems bleed the back then the front test drive if still sticking now just bleed the back only.
Have you flushed the DOT 3 if not do it first.
Sounds strange but usually works for me only usually its the front brakes that bind up.
If you ordered an all in one replacement brake kit for the 11" brakes its possible you received the wrong parts it happened to me a few times or crappy parts.
The drum brakes on Dakotas are poor at best I hate my 9" rear brakes very crappy always problems. The 98 to 2001 front disk brakes suck also after 2001 or 2002 they improved I cant recall what year they improved exactly.
Thanks for the suggestion on the bleeding. I don't know that I have bled front, then back. I always start farthest from the Master, and work inward. The brakes weren't a kit, that I remember. Think it was shoes and separate hardware kit. I can always figure out something on every vehicle I work on, but this has me NUTS. Thanks, give it a try.
