2nd Gen Dakota general discussion This section is for general discussions about your 2nd gen Dakota. Non tech related Dakota threads belong here.
Help! 97'Dakota Low beams out But High Beams work
Old 08-19-2018, 10:51 PM
tylan's Avatar
tylan
tylan is offline
Default Help! 97'Dakota Low beams out But High Beams work
Hi,
I have a 97' Dakota SLT with 3.9L engine. I noticed both of my low beam lights are out, but other lights all work fine: high beams, fog lights and turn signals.
It's my understanding that high beam and low beam share the same light bulb, does it mean the the light bulbs are okay?
Does low beam have a separated fuse or it shares with the high beam, since they share the same light bulb?
Any advice is kindly appreciated!
-T
Old 08-20-2018, 08:09 AM
HeyYou is online now
Same bulb, but, two separate filaments. The lows may simply be burned out. Verify you are getting power to the bulbs, and there is a good ground when low beams should be on.
Old 08-20-2018, 01:59 PM
tylan's Avatar
tylan
tylan is offline
Thanks for your advice, HeyYou.
I am now certain the problem isn't the bulb. I put a brand new bulb in one of the headlight, the low beam didn't come on, still the same thing.
I tested the voltage in the light bulb socket as you suggested, I am getting 0 voltage when low beam is switched on; as for the high beam, the voltage is close to 12v.
I wonder which part should I test or replace next ?
Old 08-20-2018, 09:16 PM
Find out where you are losing power. Next spot to check would be the multi-function switch. If you have tilt wheel, moving the wheel up all the way, tends to pull the wires out of the socket.
Old 09-17-2018, 02:44 PM
byronpen's Avatar
byronpen
byronpen is offline
Default Issue fixed same problem
Had same issue mine was the assembly on the column. That engage the high beans. It caused a short and shut down my low beams.
Quick Reply: Help! 97'Dakota Low beams out But High Beams work
